The maximum number of prefixes allowed from a given peer would be exceeded by processing a received update. If the peer is configured to drop the connection in this case, then the connection will be reset. Otherwise, the received update will be dropped.
Increase the number of allowed prefixes or limit the number of prefixes using more restrictive policies for this peer.
Warning
[VR %p1%] The maximum number of prefixes stored for a neighbor would be exceeded.\nNeighbor IP address: %p2%\nAFI: %p3%\nSAFI: %p4%\nDefined max prefixes: %p5%\nDropping connection: %p6%\nIdle hold time: %p7%
| Name | Type |
| p1 | uInt32 |
| p2 | VarFmtByteArray |
| p3 | uInt16 |
| p4 | uInt8 |
| p5 | sInt32 |
| p6 | sInt |
| p7 | uInt32 |
| p8 | String |
